查看: 44387|回复: 52
[资料] TL866CS升级TL866A的方法 英文版
发表于 2017-4-20 21:54:40 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Here's a quick guide to upgrading your TL866 programmer from the CS version to the A version.
This operation enables use of the ICSP port (which is easily soldered in).
游客,如果您要查看本帖隐藏内容请回复
1: Install the Programmer's software in C:\MiniPro (I used the current version included in the .zip).
2: Plug in Programmer (hope you c[/hide]hose to install the USB driver in the above step).
3: Run Programmer Software and look at the very bottom line. It should show your version TL866CS.
4: Exit back to Desktop.
5: Run the TL866.exe program.
6: Click the browse button [...] and browse for your update.dat file in C:\MiniPro.
7: Select the "Firmware Dumper" button, and hit the "Reflash" button
8: Click "Advanced", then select "A Bootloader", then hit "Write"
9: Unselect "Code protection bit", then hit "Write"
A: Hit OK to exit that menu, then select "TL866A firmware" and hit "Reflash"
B: When reflash is done, hit "Reset", wait, and hit "Reset" again.
C: Exit the TL866.exe program.
D: Run Programmer software again, look at bottom line. It should say TL866A.
E: Have fun
Please note that I performed the above steps while I was typing this,
so I am quite certain everything is correct.
Edit: There are some confirmation prompts that I skipped here because they're obvious.
Just say "Yes" or "OK" on all such prompts.
发表于 2023-8-17 10:35:58 | 只看该作者
多谢楼主,认真学习了。
51#
发表于 2023-4-1 16:50:53 | 只看该作者
我有一个这样的编程器,我想看看怎么升级。
50#
发表于 2023-4-1 16:47:45 | 只看该作者
谢谢楼主分享!看一下怎么升级。
49#
发表于 2023-3-19 23:01:46 | 只看该作者
Thank you very much!
48#
发表于 2023-3-16 14:23:54 | 只看该作者
感谢楼主的分享
47#
发表于 2023-3-15 11:56:06 | 只看该作者
看不懂,我是英文盲
46#
发表于 2023-3-14 18:27:21 | 只看该作者
看看,学习一下,谢谢您的分享。
45#
发表于 2022-9-28 22:27:40 | 只看该作者
y5eeurteutrshshfdshsyh
44#
发表于 2022-9-20 10:56:28 | 只看该作者
学习一下,有没有t48升级t56的方法
GMT+8, 2024-5-6 00:18 , 耗时 0.085570 秒, 19 个查询请求 , Gzip 开启.
