查看: 5838|回复: 0
HV Rescue Shield 2
发表于 2011-11-26 09:21:06 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
HV Rescue Shield 2Introducing the AVR HV Rescue Shield 2
The HV Rescue Shield 2 is a high voltage parallel mode fuse programmer for Atmel AVR microcontrollers.
It currently supports a wide variety of AVR chips, including the 28-pin ATmega48/88/168/328 series, the 20-pin ATtiny2313, and many 8-pin ATtiny devices (such as the ATtiny25/45/85 and ATtiny13A).  A list of supported devices is in progress, but the Rescue Shield supports many more devices than those listed on the wiki.
Update Feb 2011: Version 2.1 is in stock and shipping now!
Features:
  • Version 2.1 introduces a new and improved 12V switching circuit
  • Completely open source. Source code, schematics, layout, BOM are available.
    Custom 2-layer PCB with silkscreen and soldermask.  No more hacking and modifying perfboards to fit Arduino’s nonstandard pin spacing!
  • Onboard 12V DC-DC boost converter eliminates the need for an external 12V power supply.
  • Support for many common families of AVR microcontrollers in DIP packages.
  • Support for programming the extended fuse (EFUSE) byte.
  • An interactive mode, where desired fuses can be entered using the Arduino’s serial port.
  • Separate Ready and Burn indicators.
  • Works with the original Arduino (NG, Duemilanove, Uno) and the Arduino Mega.
New in release 2.0:
  • Support for 8-pin ATtiny devices that use High Voltage Serial Programming (HVSP) mode!
  • Mode selection at startup so you don’t have to recompile the Arduino sketch to change parts.
  • More reliable HFUSE burning on all HVPP targets.
  • Numerous minor bug fixes and speed improvements to the code.
Requirements:
    A working Arduino (tested with Arduino Uno, Duemilanove and Arduino NG) A computer with USB and the Arduino IDE installed (tested with Arduino 0021)
  • A soldering iron and basic electronics assembly skills
What you get:
  • A high quality printed circuit board with the DC-DC converter preassembled, as shown below.
  • All other components needed to build the kit
  • An Arduino sketch, assembly instructions, Eagle schematics and layout files.
What the HV Rescue Shield is not:The HV Rescue Shield is not a general purpose AVR microcontroller programmer.  That is,  it can’t be used to perform a chip erase or program flash memory.  It is intended only for programming the AVR’s configuration fuses: HFUSE, LFUSE, and EFUSE (where applicable).
The hardware implements all of the control lines to support flash programming, but the code just isn’t there.  If anyone would like to volunteer to rewrite the code to support more features, such as general flash programming, please post in the support forum!
The HV Rescue Shield is 100% open source (hardware and software).  OSHW rules!
Kits!Here is a snapshot of the components included with the kit.
Schematic (PNG format, click for larger version):
Layout (PNG format):
GMT+8, 2024-5-27 09:43 , 耗时 0.090098 秒, 23 个查询请求 , Gzip 开启.
