查看: 651|回复: 0
[电路图] 可控硅调光灯电路-TRIAC Light Dimmer
发表于 2011-5-28 23:58:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
可控硅调光灯电路-trIAC Light Dimmer
This little circuit can be used to dim lights up to about 350 watts. It uses a simple, standard trIAC circuit that, in my expirience, generates very little heat. Please note that this circuit cannot be used with fluorescent lights.
Schematic
Parts
Part
Total Qty.
Description
Substitutions
R1
1
50K Pot
R2
1
15K 1/2W Resistor
C1, C2
2
0.068 250V Capacitor
L1
1
Lamp To Be Controlled (up to 350 watts)
L2
1
Neon Lamp
tr1
1
40502 trIAC
MISC
1
Case, Knob, Heatsink For tr1, Wire, Socket For L1
Notes
1. This circuit is for 117VAC only. 220 or 240 V will burn up the circuit. L1 can be a maximum of 350 watts.
2. The circuit must be installed and used in a case.
GMT+8, 2025-12-27 03:13 , 耗时 0.431538 秒, 18 个查询请求 , Gzip 开启.
