查看: 1158|回复: 0
[无线] NXP单片GSM/GPRS多媒体解决方案
发表于 2012-1-16 16:55:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                      NXP公司的AeroFONE单片GSM/GPRS低成本多媒体解决方案PNX4903能以超低成本实现带彩色屏的音乐手机.这种单芯片解决方案集成了模拟和数字基带,RF收发器,功率管理以及音频电路.唯一的外接元件是功率放大器和存储器.完整的双频段GSM/GPRS调制解调器可以采用低成本的4层PCB做成,仅需要49个元件.本文介绍了PNX4903的主要性能以及多媒体手机的方框图.
  AeroFONE?single-chip?GSM/GPRS?low-cost?multimedia?solution
The?NXP?AeroFONE?PNX4903?enables?a?music?phone?with?color?screen?in?the?ultra-low-cost?market?segment.?By?integrating?the?analog?and?digital?basebands,?RF?transceiver,?power?management,?and?audio?circuitry?in?a?single?monolithic?IC,?the?PNX4903?solution?delivers?the?smallest?bill?of?materials?and?PCB?footprint,?along?with?the?lowest?manufacturing?and?test?costs.
  The?only?external?ICs?needed?are?a?power?amplifier?and?memory.?A?complete,?dual-band?GSM/GPRS?modem?can?be?realized?with?just?49?external?components?on?a?low-cost?four-layer?PCB.?Traditional?multi-chip?handset?designs?require?three?times?the?number?of?external?components?on?a?more?complex?PCB.
  The?hardware?reference?design?is?accompanied?by?a?flexible,?pre-integrated?and?validated?software?complement?that?reduces?R&D?expense?and?speeds?time-to-market.
  主要特性:?
  Complete?GSM/GPRS?solution?in?a?single?monolithic?IC
  GSM?Phase?2+?compliant?
  Low?power,?high-performance?0.13-m?CMOS?process
  Industry-leading?ARM926-EJS?MCU?core
  High-performance?DSP?core
  SAIC?support?for?increased?network?capacity
  Integrates?all?the?SRAM?for?a?voice-centric?phone
  Completely?integrated?RF?transceiver?
  Dual-band?Rx?and?Tx?(850?or?900/1800?or?1900)
  Proven,?industry-leading?Aero?II?technology
  Best-in-class?performance
  Complete?power?management?unit?(PMU)?subsystem?
  Integrated?battery-charging?circuitry
  Integrates?all?voltage?regulators?(LDOs?and?DC/DC)
  Integrated?audio?subsystem?
  MP3?playback?with?support?for?SD?card
  40?voice?polyphonic?MIDI?+?MP3?ringtones
  Microphone?amplifi?er?with?two?differential?inputs
  Two?differential?audio?output?amplifiers
  HR/FR/EFR/AMR?vocoders
  Alternate?40-kS/s?audio?mode?for?polyphonic?ringtones
  Speaker?phone?noise?suppression?and?echo?cancellation
  Optimized,?flexible?system?control?
  Integrated?26-MHz?DCXO?(only?need?XTAL)
  Integrated?32-kHz?RTC?oscillator?(only?need?XTAL)
  Flexible?modes?for?optimized?power?consumption
  Comprehensive?set?of?peripheral?functions
  Standard?package?
  10?x?10?mm?plastic?ball?grid?array?(PBGA)
  RoHS-compliant
PNX4903方框图:??
GMT+8, 2026-4-25 02:41 , 耗时 1.041632 秒, 18 个查询请求 , Gzip 开启.
