查看: 168|回复: 0
ADL5535以及ADL5536应用电路
发表于 2012-1-21 23:46:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ADL5535应用电路 (评估板参考电路)
Figure 10 shows the schematic for the ADL5535 evaluation board. The board is powered by a single 5 V supply. The components used on the board are listed in Table 4. Power can be applied to the board through clip-on leads (VCC and GND).Table 4. Evaluation Board Configuration OptionsComponent DescriptionDefault ValueC1, C2 AC-coupling capacitors 0.1 μF, 0402L1 DC bias inductor 470 nH, 0603 (Coilcraft 0603LS-NX or equivalent)VCC and GND Clip-on terminals for power supplyC4, C5, C6 Power supply decoupling capacitorsC4 = 68 pF, 0603; C5 = 1.2 nF, 0603; C6 = 1 μF, 1206ADL5536应用电路 (20 MHz to 1.0 GHz IF Gain Block)
Figure 10 shows the schematic for the ADL5536 evaluation board. The board is powered by a single 5 V supply. The components used on the board are listed in Table 4. Power can be applied to the board through clip-on leads (VCC and GND).Table 4. Evaluation Board Configuration OptionsComponent DescriptionDefault ValueC1, C2AC-coupling capacitors0.1 μF, 0402L1DC bias inductor470 nH, 0603 (Coilcraft 0603LS-NX or equivalent)VCC and GNDClip-on terminals for power supplyC4, C5, C6Power supply decoupling capacitorsC4 = 68 pF, 0603; C5 = 1.2 nF, 0603; C6 = 1 μF, 1206
GMT+8, 2026-3-24 11:50 , 耗时 0.093891 秒, 18 个查询请求 , Gzip 开启.
